Solved:
From support:
"Hello,
We had some issues with the cloud servers in the past weeks, but if the same issue happens again, please let us know.
Best regards,
I appreciate the help some are trying to provide with the other thread...
I think it might be easier to follow if I have a separate thread for a site.
So lets try this site Named LONG.
Hardware
Router :750G R2
CAP: wAP G-5HacT2HnD
The Router was on 6.40.8 since the CVE of 2018. The router had been using IP Cloud to update its external IP. When I connected to it yesterday... ip cloud was not working and kept showing error request timed out.
I logged into the wAP running as a cap. It was on 6.40.1.
I updated it to 6.47.4
I then DEFAULTED IT.
Logged back into the wAP and set its ip-cloud to on. I also manually set up sntp and clock to make sure they were right. And if I hit check for updates it can see that it is up to date and bring in the change log.
Here is the output:
[admin@MikroTik] > /ip cloud print
ddns-enabled: yes
ddns-update-interval: none
update-time: yes
status: updating...
I have tried disabling IP Cloud
ddns-enabled: no
update-time: yes
status: failed to connect
Then turned it back on.
Now to look at the wAP's DNS cache... you see this
[admin@MikroTik] > /ip dns cache print
Flags: S - static
NAME TYPE DATA TTL
0 cloud2.mikrotik.com A 159.148.172.251 1h34m34s
1 cloud2.mikrotik.com A 159.148.147.201 1h34m34s
NOW MOVING TO THE ROUTER.
The router was running 6.40.8 and was showing "request timed out" under IP cloud
The 750G r2 was updated to 6.47.4
It IS WORKING.
Now this is all at the same site with the WAP Directly Connected to the router.
Here is the output of the router.
[admin@mikrotik] > /ip cloud print
ddns-enabled: yes
update-time: no
public-address: 75.17x.xxx.xxx
dns-name: xxxxxxxxxxxxx.sn.mynetname.net
status: updated
Here is the DNS Cache
34 cloud2.mikrotik.com A 159.148.172.251 1h29m16s
35 cloud2.mikrotik.com A 159.148.147.201 1h29m16s
Now as you can see... both routerboards at the same physical location resolve cloud2 the same.
Yet one IPCloud is working and the other isn't
The information in this post is about THIS SITE ONLY. The other post turned into me putting results from several sites in one thread. Hopefully if I keep one train on one set of rails... it might be easier to find a problem.
The issue is that I saw various problems on MULTIPLE SITES and HARDWARE... and was trying to find a common problem.
But the site above has ONE unit that is updating IP cloud and ONE that is not.
Thanks again to everyone looking at this and trying to help.
