debugging scripting
I have a script that runs fine from the commandline when logged in as ‘admin’
when run from the scheduler, it doesn’t seem to work:
0   name="sched_backup_email" owner="admin" policy=read,sensitive last-started=jan/05/2015 13:21:32 run-count=9 source=
       /export file=current_config hide-sensitive
       /tool e-mail send file=current_config.rsc to="my@email" body="See attached file" \
          subject="$[/system identity get name] $[/system clock get time] $[/system clock get date] configuration export"
The scheduler entry:
 0   name="sched_backup_email" start-date=jan/04/2015 start-time=13:21:32 interval=1d on-event=sched_backup_email owner="admin" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive run-count=1
     next-run=jan/06 13:21:32
Nothing in the logs indicates why this did not run.
Is there any way to debug this, like having the system log what policy is missing for what operation? That would sure help figuring this out.
Hi Sejtam,
Not sure if you’ve resolved your issue yet. I had the same issue with the scheduler - script would run from the terminal but not from the scheduler. I checked all the boxes for policy (permissions), then unchecked them one at a time to find out what I needed. It became clear that I needed ‘test’ to issue commands that didn’t really seem to fit the ‘test’ description. I also needed ‘policy’ for reasons that weren’t clear. Overall I find the documentation on this product to be abysmal, and not just the grammar/spelling. It’s laid out in a less than useful fashion and is very incomplete. Too bad I like the product so much - its price/performance can’t be beaten.
I am on a quest now to find a way to ‘trace’ my scripts as they run so I don’t have to keep adding ‘log info’ statements everywhere to figure out what’s going wrong. I’ve never seen such a powerful platform lack such a basic feature. Maybe I’ll find it today - have looked before though. At least today I saw someone else asking the same question. Hopefully he got a good answer.
You could try putting your script into a text file and running it from the command line with the import utility - that will give you a line number with syntax error. If there are none, then you can create debugging commands such as log output, or setting comments on certain objects, etc.
