How to assign Dedicated speed to some one..I mean to single IP.
I am having 2 MBps and i have distributed it to some of my customers, But i want to give 512kbps up/down to one single IP at all the time.
Which is the best method
you can create a simple queue and give the higher priority than other queues. This can help.
Reagrds.
Faton
I think Simple queue will NOt work as my distribution is more than the Aquired bandwidth.
What about Queue Tree
So do u got good method !
I think priority is enough ! isn’t ? how u did it ?
make 2 parent queue
1 for dedicated bandwidth 512kbps.
2 another for 1536kbps, and make childs from here as many as u need.
i think it will solved ur problem
thnxs,
raktim
What can’t you use a simple queue with higher priority?
Thanks will Try it ![]()
