default admin account
I have several hundred Mikrotik devices of various models I am managing, and I finally was able to take the time to setup usermanager. I was going to go thru at setup them all to use the usermanager, but I ran into one problem. How can I get rid of all the default admin accounts on these devices? As it sits right now I have to still have a Full account on each device so I can delete or disable Admin. Is that right?
You can disable it, after taking away any rights to make changes.
Newer router come with a default password printed on the device so you need to register that also for each router.
That is for the new Version 7 AX Routers, the non AX routers do not have the password on the box. We are using almost all older non AX routers. I have tried disabling the Admin account and could not. I actually just tried both a ROS version 6 and 7 non AX device, and it will not let me disable the Admin account or whatever account has the admin privilages. I must be doing something wrong.
No you not doing anything wrong. It is protecting you from locking yourself out of the router.
You first have to create or have a second user with full access, and as you have already done.
Then set the Admin to read, apply, expire the password and then disable it. I prefer to expire the password after setting it to read. This to use it as a decoy/slowdown for any attackers.
update: you can even create a group with no rights instead of read. Hoping Mikrotik did not make the obvious mistake that no rights is the same as all rights. :wink:
