default-configuration and secure wifipassword
hello there,
i wonder if its possible to generate a wifi key within the default-configuration where the key is based on a secured key which cannot be reads out or known from any other people?
so any experience while setting a secret wifi key within the default-configuration without using local public data? (e.g. mac, serial oder similar)
my goal is to generate a config with all relevant paremeters incl. the wifikey, which cannot be recalculated back.
thank you!
christian
Ask in the Scripting section. It should absolutely be possible. You may even be able to use cpu-load and clock time as entropy sources.
hey,
thank you!
i´ll do it!
chris
