Default Configuration Blank After Upgrade?
Is this normal? I upgraded a box from 5.24 to 6.0 and now the /system default-configuration print shows a blank script? How do I fix this?
This is a known-problem with 6.0. However, you can use mac-telnet to access the system and setup your own configuration.
