I have a new hAP lite, RB941-2nD, v6.33.5.
I had started with the Home AP quickset and then I had changed the configuration according to my needs.
Now I wanted to disable the WLAN interface temporarily. However, when I do so, the device automatically switches to another default configuration and all my settings get lost.
How can I avoid that the device automatically chooses another default configuration when I deactivate the WLAN interface?
Thanks a lot for your support.
