Default Configuration for RB/2011UAS-2HnD-IN
Can anyone provide the output from /system default-configuration print on one of these boxes?
-Eric
#| Wireless Configuration:
#| security-key: 374902B0B79E;
#| mode: ap-bridge;
#| band: 2ghz-b/g/n;
#| frequency: 2412;
#| ht-chains: two;
#| ht-extension: 20/40mhz-ht-above;
#| WAN (gateway) Configuration:
#| gateway: sfp1 ether1 (renamed with extension ‘-gateway’);
#| firewall: enabled;
#| NAT: enabled;
#| DHCP Client: enabled;
#| LAN Configuration:
#| LAN Port: bridge-local;
#| switch group: ether6 (master), ether7, ether8, ether9, ether10
#| (renamed with extensions ‘-master-local’ and ‘-slave-local’)
#| LAN IP: 192.168.88.1;
#| DHCP Server: enabled;
      :global action;
      :local dhcpEnabled 0;
      :local wirelessEnabled 0;
      #check for wireless and dhcp packages
      :if ([:len [/system package find name="dhcp" !disabled]] != 0) do={
      :set dhcpEnabled 1;
      :if ([:len [/system package find name="wireless" !disabled]] != 0) do={
      :set wirelessEnabled 1;
      # Apply configuration.
      # these commands are executed after installation or configuration reset
      :if ($action = "apply") do={
      # wait for interfaces
      :while ([/interface ethernet find] = "") do={ :delay 1s; };
            :if ( $wirelessEnabled = 1) do={
                    :local count 0;
                    :while ([/interface wireless find] = "") do={
                            :set count ($count +1);
                            :if ($count = 60) do={
                                    :log warning "DefConf: Unable to find wireless interface";
                                    /ip address add address=192.168.88.1/24 interface=ether1;
                                    /quit
                            :delay 1s;
                    /interface wireless set wlan1 mode=ap-bridge band=2ghz-b/g/n frequency=2412 ht-txchains=0,1 ht-rxchains=0,1 \
                            disabled=no wireless-protocol=any distance=indoors
                    :local wlanMac  [/interface wireless get wlan1 mac-address];
                    :set ssid "MikroTik-$[:pick $wlanMac 9 11]$[:pick $wlanMac 12 14]$[:pick $wlanMac 15 17]"
                    /interface wireless set wlan1 ssid=$ssid
                    /interface wireless security-profiles set default wpa-pre-shared-key=374902B0B79E wpa2-pre-shared-key=374902B0B79E mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk
                    /interface wireless set wlan1 channel-width=20/40mhz-ht-above ;
            /interface set sfp1 name="sfp1-gateway";
            /interface set ether1 name="ether1-gateway";
            :if ( $dhcpEnabled = 1) do={
                    /ip dhcp-client add interface=sfp1-gateway disabled=no comment="default configuration";
                    /ip dhcp-client add interface=ether1-gateway disabled=no comment="default configuration";
            /interface {
                    set ether6 name=ether6-master-local;
                    set ether7 name=ether7-slave-local;
                    set ether8 name=ether8-slave-local;
                    set ether9 name=ether9-slave-local;
                    set ether10 name=ether10-slave-local;
            /interface ethernet {
                    set ether7-slave-local master-port=ether6-master-local;
                    set ether8-slave-local master-port=ether6-master-local;
                    set ether9-slave-local master-port=ether6-master-local;
                    set ether10-slave-local master-port=ether6-master-local;
                    add name=bridge-local disabled=no auto-mac=no protocol-mode=rstp;
            :local bMACIsSet 0;
            :foreach k in=[/interface find] do={
                    :local tmpPortName [/interface get $k name];
                    :if (!($tmpPortName~"bridge"  || $tmpPortName~"sfp1" || $tmpPortName~"ether1"|| $tmpPortName~"slave")) do={
                            :if ($bMACIsSet = 0) do={
                                    :if ([/interface get $k type] = "ether") do={
                                            /interface bridge set "bridge-local" admin-mac=[/interface ethernet get $tmpPortName mac-address];
                                            :set bMACIsSet 1;
                                    add bridge=bridge-local interface=$tmpPortName;
            /ip address add address=192.168.88.1/24 interface=bridge-local comment="default configuration";
Where can i download the default config backup file from the RB2011UAS-2HnD i have lost the backup file
