default for freeradius
I am trying to setup everything so that if the user/mac is not in the freeradius table then mikrotik dhcp will stick the user/mac in pool xxx rather than flat out denying them access, any ideas on how to do this?
hotspot using freeradius. it can be done.
i do not want to have to use hotspot, just straight dhcp with radius backend. I just need some way of saying if user not found do attributes x whether it be in freeradius or mikrotik?
Freereadius has /etc/freeradius/radius.conf (AFAIK) and there is option DEFAULT.
Hope this helps.
Gregor
grzesjan, are you using this? would you mind posting a bit of conf for me to see?
thanks
Yes I use. My config is unuseful for you. Look for comments and search
for DEFAULT statements. And use google - it helped me.
Gregor
