I have configured in my WLAN1 the Hotspot, so I don’t want that wireless hotspot users cannot comunicate between them.
I have chosen default forward to NO, but still can communicate.
Have I to do anything more to block communication between hotspot users in wireless interfaces?
Then you should only set your WLAN1 interface property called
DEFAULT FORWARDING to NO
and property DEFAULT AUTHENTIFICATION to YES
this way, when a new client comes into your public wlan he can authenticate and get ip address, but he cannot ‘talk’ to other clients because DEFAULT FORWARDING is off…
this should work fine i think…
what version of mikrotik you have??? is it licenced???
if it does not work then you should send more details about your wlan1 configuration…
got interface > wireless > and type print
and send here the output you get… this can help me and other guys on forum to help you…
