I need example how to setup wireless client and mikrotik with default forward disabled I need to setup client to see another client but to use mikrotik firewalls.
Thank very much
Thank very much
Not sure exactly what you want to accomplish. Are you saying that you want all of your clients to go through the firewall rules when attempting to connect to each other except for these two clients?
Are you using the access list to authenticate your clients? If so, you can set up forwarding in the access list for these two clients and leave every elses forwarding option off.
D~
