In a wireless connection we have the feature of default forward, which would enable or disable
the capability of browsing clients computers connected to the wireless interface.
Is there any option similar to this, which can be applied on an ethernet port, so clients
connected to the same ethernet using switch, should not be able to access each other?
Remember that all wireless clients access each other via the single wlan1 port, which means you can disable forwarding.
But on Ethernet, you need a switch/hub for this so as macgaiver says, the only way is to use VLANs. By default, all ethernet ports on a switch are in the same broadcast domain (and VLANs disables this).
Yes of course, it’s the first thing that crossed my mind, switch with Vlans.
But you know, I was wishing of a more concentrated solution within Mikrotik
RouterOS, silly somehow huh
thanks all, but I’m just a Beginner and i want you to tell me how can i do VLans to all of my clients to isolate all of them, can i ???
all i want is to give me a quick example…
Yes Pepo, first of all you need a managed switch which gives you the capability to control its ports.
This way you can isolate different computers which connect to the switch. How? Tagging the ports of the switch. Lets say you have a 16 port managed switch, and you want to separate 4 of the computers to the rest of them. You tag those four ports with tag1 lets say and the rest with tag2. The thing gets just a little more complicated when you have two swithes, but the idea remains the same.
Back to the topic. I have seen that even using different IP addresses on the same ethernet port does not make the computers unvisible. Lets say we have the following configuration:
192.168.1.1/24 ether1
10.1.1.1/29 ether1
than we do have some computers on the first network and some others on the second. I have noticed that these can still see each other, not by their netbios name, but by their IP address. This is because I think thay have deafault route on the same ethernet port of the router, like:
