default-forwarding
From http://www.mikrotik.com/docs/ros/2.8/interface/wireless.simple
default-forwarding (yes | no; default: yes) - to use forwarding by default or not
What does that exactly mean ? Is it to enable/disable possibility for the clients to talk to one another or maybe it enables/disables only one to one communication for the customers?
YazzY
yes, if default forwarding is off, the wireless clients won’t be able to communicate with eachother
What if you have two APs, one client connected to one of them and the other client connected to the other AP, both APs are on the same network.
Will they still be able to communicate with eachother even with default forwarding turned off ?
Yes. they still be able to communicate with eachother even with default forwarding turned off.
