I’m pretty new to the whole Mikrotik thing, and I am having some problems setting up my PPPoE server.
here is a picture of my network to help you.
I can get a host to connect to the PPPoE server, which is fine, but it is not being given the correct subnet mask or default gateway.
I have set up an IP pool so that it will provide an IP between 192.168.2.16 and 192.168.2.25.
ipconfig tells me that I have
IP address: 192.168.2.252 <this is expected, and ok
Subnet mask: 255.255.255.255 <I’m sure that this is not meant to be. the other interfaces on the subnet are all /24
Default gateway: 192.168.2.252 < definite problem here. how do i get out of my network if its gateway is me?
If anyone can help me with this, it would be much appreciated. I have looked for ages both on this forum and the manual and havent found a solution :-/
