I would like to create a scheduled script for default gateway failover?
Any ideas where to start?
You can create a script for changing the default gateway whenever you want, but surely you mean a script for when the link goes down? Is netwatch not what you are referring to?
Do you mean removing a specific gateway with load balancing, sorry maybe I am missing the point here.
hi yogi,
thanks for the reply I will look into netwatch.
/ tool netwatch
add host=3.3.3.3 timeout=1s interval=1m up-script="/ip route set \[find comment=Default\] gateway=1.1.1.1" \
down-script="/ip route set \[find comment=Default\] gateway=2.2.2.2" comment="" disabled=no
just add the comment Default to your route in question
You should also add a static route to the host that you’re checking…ie
add dst-address=3.3.3.3 gateway=1.1.1.1 comment="Always use this default gateway for netwatch IP"
I had to do this to prevent netwatch from thrashing about when the primary connection was down.
i have rb 750 os 4.13 and dont work this script ?
