default masquerade rule keeps changing interface
I have 2011UAS-2HnD and I’ve recently upgraded to ROS 6.2.
Since the upgrade I started having problem with pppoe interface and default masquerade rule configured on it:
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway name=pppoe-o2 password=ADSL profile=default-encryption service-name=DATA use-peer-dns=yes user=ADSL
add action=masquerade chain=srcnat comment="default configuration" out-interface=pppoe-o2
The problem is that all of sudden (about once a day) the masquerade rule from unknown reason changes the out-interface to ether1-gateway.
I am not using any scripts.
Any clues what makes the nat rule changing the interface?
thx,
Antony.
Just guessing, but maybe a parsing bug. Rename pppoe-o2 to be pppoeOut2 and see how that goes.
