I was probably stupid in buying a ‘preconfigured’ Mikrotik routerboard Hap from a popular shopping website. It was
pre-configured to the VPN of a provider but there had been posts on their website that you could reset it
if you wanted to change the provider.
I just wanted it ‘next day’ so I thought I could just factory reset and enter the VPN details of my own provider.
I did the factory reset .It is now showing logged onto my network as a device called ‘mysetup’
When I connect to that ip address I get the prompt for username and password. User is defaulted
to admin
So, I’ve tried blank, admin, password, 1234.
It’s so annoying, why isn’t the password the default that everyone says it should be (which is blank)
It’s running RouterOS v6.37.3
Does anyone have any idea ?
