Default Rate-Limit profile
Hi there,
When using user manager, is it possible to set a default rate-limit profile so that it will be assigned to new users without having to enter it each time?
Cheers
Anyone?
yes you can set the rate limit on the default profile for your hot-spot, and its checks the local hotspot first and then the um database, if you set it in the hotspot then anyone not haveing a rate set in um would be bound to that though
Rabitech, as well you may create batch of users, when rate-limit will be assigned for all of them.
