After upgrading a box from 2.7.20 to 2.8.8, routing nolonger works.
It seemed as though it got the interfaces crossed, so I cleared the
config, setup r and system reset didnt seem to take everything out,
so took the hotspot/firewall stuff out manually.
interface print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R ether1 ether 0 0 1500
1 R ether2 ether 0 0 1500
ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 xxx.9.241.19/29 xxx.9.241.16 xxx.9.241.23 ether2
1 xxx.9.242.1/24 xxx.9.242.0 xxx.9.242.255 ether1
ip route print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, r - rip, o - ospf, b - bgp
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 IS 0.0.0.0/0 r xxx.9.241.17 1 ether2
1 DC xxx.9.242.0/24 r 0.0.0.0 0 ether1
2 DC xxx.9.241.16/29 r 0.0.0.0 0 ether2
The gateway shows as invalid and pinging the gateway on the same
subnet as the ether2 gives 'no route to host'
ip firewall connections show connections, other Mtik neighbors see the
box, but cant seem to ping it. It sees some arp addresses.
Any suggestions welcome KenK.
