Default route pref-src
Hello there,
I have an odd situation with a RB1100AHX2. Until last week it was running ROS v5.25. Since I’ve upgraded it to 6.9(6.10) it has a strange behavior for outgoing packets: I have several IPs declared on outside interface (eg: 12,13,14,100,150). Default route pref-src was not set and for some reason the src IP for outgoing connection was the first I configured, let’s say 100. After the upgrade, the outbound src IP was 12. I set the “pref-src” for default route to 100 and still making outgoing from 12.
It’s quite strange. Can you please give me a hint what I’m doing wrong?
Are you using a masquerade on that interface? If so, you should use src-nat instead.
What are you using to determine which of those ips should be used as a src-address in communication with internet devices?
Thanks.
Migrating from masq to srcnat and it worked just fine. Don’t know what’s wrong with me these days, I knew that… :slight_smile:
Q: What are you using to determine which of those ips should be used as a src-address in communication with internet devices?
A: Nothing, just masq. Actually this is what’s strange. Until the upgrade the connections made through masq rule was set to 100… and I don’t know why…
I did a bit of experimenting a few years ago, and found the masquerade used the last ip entered in “/ip address” for that interface as the masquerade. After your upgrade, it may have rearranged that order and used the lowest ip.
It is always best to use src-nat when you have multiple ips assigned to the same interface. That insures it uses the ip you are expecting.
