Wyoming
December 20, 2006, 7:31pm
1
I can’t seem to get RIP to redistribute the Default route to other routers. Does anyone know how to do this. I have it setup in the main Mikrotik and that mikrotik set to redistribute static routes but it will not show up in the other mikrotik.
Equis
December 20, 2006, 8:34pm
2
I think restribute static is not teh same as default (in ospf anyway)
Have you got distribute default turn to always?
Wyoming
December 20, 2006, 8:38pm
3
Where do you turn that on at? There is no place to turn on redistribute default in the Rip Setting.
Equis
December 20, 2006, 8:42pm
4
I use Winbox 2.9.38 with routeing-test, it is there
Wyoming
December 20, 2006, 8:44pm
5
Ok. Then the regular routing package doesn’t have it. I will have to update to the Routing test package.
Thanks for you help
Wyoming
December 20, 2006, 8:56pm
6
My next problem is I can’t find a routing-test package for router boards. Do you know where I can get one? I can’t seem to find it on their site.
Equis
December 20, 2006, 10:07pm
7
If you look under package is it listed but greyed out (in winbox)?
