created NAT rule with ISP dynamically assigned IP. Anytime the router restarts or is powered down won’t get access to the internet unless the NAT rule is manually updated with the new IP.
Is there any way to write a rule to overcome this issue?
(1) Your vlan1 makes no sense.
If you need if for the wan connection then why are you trying to create an IP pool as well ??
Additionally there is no reason to attach ether1 to the bridge!
(2) Again remove any /interface bridge vlan settings - not required, you have a bridge with ports etc, the vlan is just for the wan connection.
(3) the bridge is not an IP DHCP client that should be removed.
(4) Why two rules that say the same thing??
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=masquerade chain=srcnat log=yes out-interface=vlan1 out-interface-list=WAN
plus you can only have one not both out interface and out interface list.
Several things in there are weird. For start, I don’t see any NAT rule with IP address you could be updating. But I do see default route that might need it (gateway), which is unusual, because normally you just let DHCP client add dynamic default route. Also to have both DHCP servers and clients on both LAN and WAN is probably not correct. And those two wifi routes don’t look correct either.
I have only changed the default config that was not working - I did not create this configuration.
I could not find proper documentation on mikrotik and I’ve searched (initial router setup is old and a mess).
ether1 is a slave (attached to bridge) and cannot get it to have a dynamic IP from ISP.
I could not find a way in documentation to make it a master if it is still possible with ROS v7. How do I make ether1, supposedly WAN interface, a master?
Hence I created a VLAN which takes required settings for internet to work (this is a fiber network setup, and I could not get the ether1 to obtain an IP)
router does not work on the internet if I do get the NAT rule to have VLAN as out interface (if ether1 is selected, an error stating ether1 is slave is thrown)
DHCP-client: bridge was removed because when added does not get an IP address, it is always in Status: searching…
This is the only config I could get the router to work.
