default-small queue, simple queue and counting bytes
I discovered that if you have rule in simple queue and the king of queue is default-small for each… the total bytes, tx bytes and rx bytes remain in 0, not counting… is normal that? is a problem in 6.22?
Thank you
Use default and you will not have a problem. It is the recommended setting in the wiki. I don’t understand why they don’t make “default” the default setting.
Yes my friend. I am using stochastic and PCQ but i realized that some simple queue don´t count. I was going crazy and I forgot some queue switch to default, or pcq or sto…
But, why is not counting? is a bug?
Thank you
