default wan setting.
Hello People,
i have just setup Mikrotik RB750GR3 i have three Wan connection, & load balancing and failover is working fine,
now i am facing issue Wan2 or sometime Wan3 works as default internet i want Wan1 to set on Default only. whenever internet is working it should be with Wan1.
help please
You contradict yourself …
either you have load balancing or you dont.
WAN1 cannot be primary in a load balancing scenario for example.
Perhaps you are confused as to what you want???
