Tx
transmit rate
,Rx
receive rate
,Noise Floor
noise floor is erm, nose floor - this is at what level signal cannot be recognized as signal due to noise in environment
,SNR
signal to nose ratio - bigger the value means everything is ok
, Tx CCQ
how much you get from theoretical available
, the db for the antenna
depends on antenna - wrong values can bring you to broken link
here are the readings on my station:
Band: 5Ghz
Frquency: 5700 Mhz
Tx/Rx Rate: 6Mbps
Tx/Rx Signal Strength: -61/-76
Noise Floor: -112
Signal to Noise: 36
Tx/Rx CCQ: 64/0
Overall Tx CCQ: 0
Ack Timeout: 28
the station now is not very far from the AP, i will soon install another station that is somehow far, so please let me know which values should i monitor to make sure my link is stable.
