defrent subnet appear!
hey guy i have strange ip 192.168.10.4 tcp and udp showing in torch at WAN Ethernet port can anyone please what the hell is this and where this come from?
ether1 port = WAN and public static ip and nated
ether2 port = 192.168.1.0/24
ether3 port = 192.168.2.0/24
ether4 port = disable
ether5 port = disable
thanks
Add rule to drop invalid packets (the packets should be dropped), if they do not belong to any active connection on the router.
and ask your ISP about those IPs =)
hi chupaka the problem been solved i found out the damn netgear router this router been use by other department office i tried to pullout then suddenly the 10.4 disappear.
thanks
