I want to delay a script by 4 seconds.
/ ip firewall connection remove [find]
How should I set this?
Thanks for your help.
:delay 4000ms;
But I feel there is more to your question than a simple delay
Thanks for your reply
The problem is that I don’t know where to place the delay in the script.
Something like that or am I wrong
/ ip firewall connection remove [find] :delay 4000ms;
You want a delay after each entry from firewall is removed? Or after all entries are removed?
I want to run a script and pause the last line for 4 seconds
ip route disable [find dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx]
:log error “ISP2 is down”
Here must come the pause for this below command
/ip firewall connection remove [find]
Thanks for your effort.
Ip route disable [find dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx]
:delay 4000 ms
Thanks for your help. I appreciate this.
Greatings
