Delete all files from RB
I recently buy a RB750GL and has lots of configuration, so I reset and upgrade to latest version.
The problem is that there are lots of files. Could I delete all files? Need I preserve some files or directories?
Best regards.
usually you can delete all files.
Folders like the hotspot folder get generated automatically by the hotspot server if not specified.
Backup files are created before a reset an can also be deleted.
What kind of files do you have on your device?
Best regards
1001001
Thanks!
I delete all except “skins” folder, could I delete it?
Best regards.
Well yes you can delete it but it’ll probably reappear. It’s the folder used to store Webfig skins so routerOS will probably recreate it.
Thanks!
I delete it, reboot the RB and now there are not any entry in Files. It works great.
Thanks and regards.
