Hi all,
I am experiencing an issue with a RB411U on 6.34.2 with a sierra wireless MC8705 - If the mikrotik is restarted or the lte interface dropped and reconnected then it adds and overrides the static default root with a default route of the lte interface.
This happens even if the add default route option is deselected under the lte interface properties. If I select the option and set the distance to 2 for example, it will disregard that and override the default route in any case. Possibly a bug ?
What can I do to stop this or how can I script it to delete the lte route as soon as it is present ?
