Delete v7 configuration (old upgrade attempt) before trying to upgrade again from v6 to v7.2
Hello everybody,
as soon as “stable” v7 was out I tried to upgrade many devices. Two of them gave a lot of problems - a RB4011iGS+ and a CRS326-24G-2S+ . The first was unstable, all the ethernet ports were off, had to force downgrade to v6 to make it stable again. The second looked like of but after 30 mins or so started to be unstable and show packet loss on all the ports. Back to v6, everything ok so I decided to postpone the upgrade.
As I need WG and Zerotier (using them on a Caps AC at the moment, but I’d prefer to have them on the 4011), I’d like to test again and go to 7.2. As fas as I understand, going to 7.2 on an already upgraded device will bring me back to the broken already-imported v7 config.
Is there a way to delete the old v7 config from the v6 and force re-importing after upgrading?
Thank you
