deleting bridge interface for better throughput.
I have an PPPPoE VLAN tagged internet setup on ether1, all Ethernet ports are linked together through bridge interface, which I hear can significantly reduce performance/throughput.
I want delete the bridge interface and connect all the ports using the switch interface in the same RB951G-2HnD router.
if anyone can supply me with direct running code for the terminal, I will be very pleased.
thanks a lot.
Since ROS 6.41 you can enable hardware offloading on bridges and for a simple setup (one bridge, no vlans, bondings etc.) this will be the same as using switch chip in switch menu.
thank you co much mr.XVO,
Since my ISP requires VLAN on PPPoE neccessary to establish internet connection. I must activate at least one VLAN on ether1 port.
hardware offloading you mean fast-track ? enabled from firewall tap rules?
thanks again and sorry that I am a big network noob .. xD.
You can delete the Bridge if only one Interface or VLAN is connected to it.
As soon as you have more Interface I do not see how you can remove it.
Look at VLAN 40 here (it does not use Bridge):
http://forum.mikrotik.com/t/sofware-vlan-bridge-on-ruteros-explained/122534/1
VLAN interface on ether1 is ok, for hw-offload to work you need no vlan filtering on the bridge itself.
No, hardware offloading is a new feature option that makes a bridge behave like a dumb switch when it is possible.
So switching will be done by switch chip.
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#Bridge_Hardware_Offloading
thanks to both of you guys, I have managed to enable HW-offload on the bridge as Mr.XVO suggested. now it is fine.
thanks to both of you, solved.
