Dell PowerEdge r210
Mikrotik work in dell poweredge r120, it sata hd? ethernet One dual-port Broadcom BCM 5716 1 gibt?
http://www.dell.com/us/en/enterprise/servers/poweredge-r210/pd.aspx?refid=poweredge-r210&cs=555&s=biz
Dear i tried to install mikrotik on Dell R 210 without seccess
as soon as mikrotik start to install system halted
any one here has an idea ??
try v5beta5
so, it worked?
Try v5beta6.
I have absolutely no clue if this will work as I haven’t tested this, and I have NO idea which drivers were added to beta 6, but I’m going to make a recommendation anyway.
did you manage to make it work? we want to buy one R210 to run mikrotik as main gateway.
Regards
Working fine for me on 5.0rc7, haven’t upgraded to anything later yet, but later versions should also work. Stock R210 with on board NICs (Broadcom). Dell’s Intel option (dual PT gig should also work, that card is based on the 82576 chipset, which is supported).
