Hello, I need help.
I’m doing price of DELL servers to install the MikroTik RouterOS x86 and I wonder if this hardware configuration is 100% compatible and recommended.
· Dell 13th generation rack server 1U, 2-socket Intel Xeon E5-26xx v3 and Chassis processors with support for up to four 3.5 "disks
· Intel Xeon processor E5-2640 v3 8 cores, 2.6GHz (Maximum frequency of 3.4GHz), 20MB cache, QPI link 8.00GT / s
· Memory 8GB RDIMM, 2133MT Transfer Rate / s, Dual Rank, width Given x8
· Hard Disk 300GB 10K RPM SAS 12Gbps 2.5 ‘’ Hot-plug with Carrier 3.5 "
· Disk Controller H330
· No RAID configuration
· Support up to 12 DDR4 memory modules (capacity reduced by half with one processor installed)
· Video Card Matrox® G200eR2 with 16MB memory
· IDRAC8 Express
· Drive DVD +/- RW SATA Internal to chassis 4HD
· Sources redundant (1 + 1) of 550W, Dual, Hot Plug
· 2 Cable C13 strength, BR14136 (Brazilian standard), 250V, 10A, 2 meters long
· Network Adapter On-board Quad-Port 1GbE
· Network Card Intel Ethernet Server Adapter I350 QP 1Gb, Low Profile
· Intel Network Adapter X520 SD 10Gb DA / SFP +, Low Profile
Thank you. ![]()
