Do you have a 3-chain direction antenna? Doubt so. But anyway, using two cards with 2 tx chains on one and 2 rx chains on the second you can reach that speed with full duplex. Just need to try. I havent tried it.
PS: Do not beg for karma. Does not look good. There is no contest, you will not gain anything just by having points on your account…
saintofinternet - there are no full-duplex cards available. Anything like this would be pseudo full-duplex.
That being said I use two triple chain cards w/three dual-pol antennas. One of the antennas I set at a 45 degree polarity angle. This allows the 3 chains to be on different polarities. Although using the 45 degree is not perfect it works well and I get reasonable spacial RF separation for a 2 mile link.
I also do not use OSPF but instead standard routing with the distance cost set higher on one link on each side. This makes it act as a full-duplex setup w/o a lot of overhead. It also has the side benefit of if one of the cards fails the link stays up, albeit ~ half speed but still up…
You’ll need a fast RB, no filtering or nat, use an ‘edge’ router for all of that, something w/o wireless in it.
I easily hit 300mbps, past that it is difficult to have something be able to tx/rx (FTP, etc) a file through the RBs that is fast enough to actually achieve higher speeds. I know that at 300mbps I’m only hitting about 40% on the CPU, at 200mbps it about 35%…
