Design Skin button disabling, possible?
I am editing a skin to simplify set up of Groove 52HPn CPE to ease connection to AP’s. I’ve pared down the Quick Set page to the bare minimum for selection and connection to AP’s. Only problem I’ve encountered is hiding the following buttons - ‘Check for Updates’, ‘Reset Configuration’, ‘Apply Configuration’.
The ‘group’ that will use this skin only has Read, Write and Web policies enabled. So, it does not appear that clicking these buttons has any affect. However, to avoid confusion by the user I would prefer they did not appear at all on the skin.
Is there some way to hide them as with the other items that have simple check boxes?
Thanks in advance!
