Hello all,
I wonder if somebody could help us out on the following issue. My colleague and i spent literally 10 hours searching, troubleshooting and experimenting without success.
Job description: We are trying to add 3 vlans to the Mikrotik. Vlan 10, 20 and 30. We want to make Eth5 the trunk port with all 3 vlans tagged. Also we want to make Eth2 an access port in vlan20 and Eth3 an access port in vlan30.
This are the steps we followed so far:
1. Rename the ethernet interfaces to something that makes sense and clear the master/slave memberships on ports 1 trough 5
set [ find default-name=ether1 ] master-port=none name=eth1
set [ find default-name=ether2 ] master-port=none name=eth2
set [ find default-name=ether3 ] master-port=none name=eth3
set [ find default-name=ether4 ] master-port=none name=eth4
set [ find default-name=ether5 ] master-port=none name=eth5
set [ find default-name=ether6 ] name=eth6
set [ find default-name=ether7 ] name=eth7
set [ find default-name=ether8 ] name=eth8
set [ find default-name=ether9 ] name=eth9
set [ find default-name=ether10 ] name=eth10
2. Add the VLAN interfaces
/interface vlan
add interface=eth5 l2mtu=1594 name=vlan-10 vlan-id=10
add interface=eth5 l2mtu=1594 name=vlan-20 vlan-id=20
add interface=eth5 l2mtu=1594 name=vlan-30 vlan-id=30
3. Add the IP addresses
add address=192.168.10.254/24 interface=vlan-10 network=192.168.10.0
add address=192.168.20.254/24 interface=vlan-20 network=192.168.20.0
add address=192.168.30.254/24 interface=vlan-30 network=192.168.30.0
3. Add the DHCP networks
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.254 netmask=24
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.254 netmask=24
add address=192.168.30.0/24 dns-server=8.8.8.8 gateway=192.168.30.254 netmask=24
4. Add the DHCP pools
add name=vlan-10-dhcp-pool ranges=192.168.10.10-192.168.10.50
add name=vlan-20-dhcp-pool ranges=192.168.20.10-192.168.20.50
add name=vlan-30-dhcp-pool ranges=192.168.30.10-192.168.30.50
5. Add the DHCP Servers
add address-pool=vlan-10-dhcp-pool disabled=no interface=vlan-10 name=vlan-10-dhcp-server
add address-pool=vlan-20-dhcp-pool disabled=no interface=vlan-20 name=vlan-20-dhcp-server
add address-pool=vlan-30-dhcp-pool disabled=no interface=vlan-30 name=vlan-30-dhcp-server
Break: @ this point we have 3 vlans, 3 networks, 3 DHCP servers and one trunk port. All 3 vlans are added to Eth 5. Now; lets configure the untagged vlan ports eth2 and eth3.
6. This command sets the access ports. VLAN 20 on port eth2 and VLAN 30 on eth3
set eth2 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set eth3 default-vlan-id=30 vlan-header=always-strip vlan-mode=secure
7.This command allows the router (CPU) to talk to the switch
add independent-learning=yes ports=eth5,eth2,eth3,switch1-cpu switch=switch1 vlan-id=10
add independent-learning=yes ports=eth5 switch=switch1 vlan-id=20
add independent-learning=yes ports=eth5 switch=switch1 vlan-id=30
8. Remove eth2 from bridge local
remove 0
9. Tie ports 2,3 and 5 together with master / slave config
set [ find default-name=ether2 ] master-port=eth5 name=eth2
set [ find default-name=ether3 ] master-port=eth5 name=eth3
The result of all of this is a little bit disappointing. The trunk port works flawlessly. The access ports don’t. We really hope that somebody can help us out and explain the relation between the switchchip - CPU and vlan interfaces.
Attached is the complete configuration and a very simple diagram.
Many thanks,
Kind regards,
Patrick
