destination host unreachable
dear all,
I using mikrotik for badwidth managemnent, but unfortunelly it;s not working.
here’s my net config
ISP-----Router-------Mikrotik-----swicth
Router
eth0 ip : 202.144.94.66/30
eth1 ip : 202.144.85.161/30
mikrotik
eth0 ip : 202.144.85.162/30
eth1 ip: 202.144.85.169/29
so My client is from 202.144.85.170 - 174 /28
then I create static queue on mikrotik
destination 202.144.85.170 example mak 64
destination 202.144.85.171 example mak 128
also I create static route 0/0 gateway 202.144.85.161
The probelm is,
I cannot ping to the router on 202.144.85.161 , its say destinantion host unreachable.
then I try to ping from mikrotik, no problem, even I can ping to http://www.yahoo.com
did I mist something , why from my client cannot pass 202.144.85.161
deden
Hi
You can use Mikrotik as you want, without add any devices to make ways to the world.
this link make easy way and nice sleep for next time:
http://www.mikrotik.com/docs/ros/2.9/guide/basic
regards,
BalimoreDOTcom
hi,
It;s not answer my problem???
t
Kind of a dumb question, but can you ping the .169 address and if you can did you set it as teh gateway. If the address assignment on the .169 side of the mikrotik router is a /29 then the gateway of your computer is .169 and the netmask is 255.255.255.252, if it is a /29 then the gateway is the same, .169 and the netmask is 255.255.255.248 .
yes,
sure I set my client
IP from 202.144.85.170 to 174
gateway 202.144.85.169
netmask 255.255.255.248
but, from my client side I canot ping ?pass 202.144.85.161
but if I try to ping from mikrotik using terminal, no problem
in the Router do you have a route in the route table to reach the /29 ?
Needs to be like :
destination 202.144.85.169/29
gateway 202.144.85.162
hi,
Why I do need that? its
in router I just make a route o/o to my isp gateway.
if
it;s for outside network to inside, right, CMMIW.
I just wonder why if I poing from terminal mikrotik > no probelm but if I ping from PC Clinet it’s like cannot pass 202.144.85.161 . so the client canot connected to internet
t
Well if its for return then the ping requests won’t know how to come back to the far side(169/29) of the Mikrotik router.
yes,
but why from terminal mikrotik its reply!
and I do not only need just success pinging, but also to get connected to internet.
t
Well the mikrotik should be able to ping because the /30 connects eth1 on the Router and eth0 on the Mikrotik. eth1 on the mikrotik is hidden from the Router because it doesn’t know that that subnet is there without a route. if you add that route in the Router then you would be able to access the internet and ping, etc.
ok, so I add a route in my cisco
ip route 202.144.85.169/29 202.144.85.162
beside 0/0 to ISP Gateway
right
yup, should work.
ok,
I wil try it, thx,
can I know your yahoo ID or email
t
email :
jonathan@etxrn.com
