Destination NAT with PPP Connection
I’m trying to setup Destination NAT on a PPP interface. I have made the following rules however I dont beleive they are correct?
[admin@MikroTik] /ip firewall nat> print
 0   chain=srcnat action=masquerade out-interface=ppp-out1
 1   chain=dstnat action=accept protocol=tcp dst-address=10.0.0.1
     in-interface=ppp-out1 src-port=22 dst-port=22
 2   chain=dstnat action=accept protocol=tcp dst-address=10.0.0.1
     in-interface=ppp-out1 src-port=25 dst-port=25
 3   chain=dstnat action=accept protocol=tcp dst-address=10.0.0.1
     in-interface=ppp-out1 src-port=80 dst-port=80
 4   chain=dstnat action=accept protocol=tcp dst-address=10.0.0.1
     in-interface=ppp-out1 src-port=443 dst-port=443
 5   chain=dstnat action=accept protocol=tcp dst-address=10.0.0.1
     in-interface=ppp-out1 src-port=3389 dst-port=3389
I want to allow inbound TCP on 22, 25, 80, 443 and 3389 to IP 10.0.0.1.
Any help would be appreciated.
Liam
Remove the src-port property from those rules and they should be fine.
I could remove that, however that will break my LAN’s internet access.
Can I setup a PPP connection to DMZ to an IP instead?
do you have a firewall rule?
a nat rule doesn’t have an action like accept or deny.
something like this could help
add action=accept chain=input comment=“Access” disabled=no dst-port=
22 in-interface=pppoe-out1 protocol=tcp
if you want to redirect all incoming requests for these ports to address 10.0.0.1, then you should use the following:
chain=dstnat in-interface=ppp-out1 protocol=tcp dst-port=25 action=dst-nat to-addresses=10.0.0.1 to-ports=25
