Detail Website Logs visited by the Users
i have installed my RouterBoard RB450 which is communicating with the radius server at one of the location. The users are getting authenticated through the radius server. However i am facing a challenge as i need to maintain the detail logs of the websites visited by the users. I have no idea as how this can be achieved. i would appreciate if someone can provide me with the router board model no which can support such kind of requirement. Thanking you in advance.. Waiting for a suggestion..!!!
Set up proxy and enable webproxy logs.
If you want more advanced monitoring then:
http://wiki.mikrotik.com/wiki/Proxylizer/Introduction
dear Mrz,
thnk you very much for ur prompt reply and suggestion. i had gone through the proxylizer as suggested by you… i found tht i would be requiring additional hardware apart from my mikrotik router. In the meantime, i was told by few guys that Mikrotik RB450G has a built in feature which provides such kind of detail logs of websites. Also i have my own login portal page in which user has to enter the credentials as present in radius server database for authentication. I had been told that using a proxy will prevent the users from getting the login page. So can you please provide clarification if any web page logging features are present in RB450G and if i use proxy server, will it affect the display of my login page…
thnk you
