Hi I have a request from a customer.
Have not found this in 2.8.16, not sure about 2.9 beta…
- can you gather/display stats from the Ethernet adaptor using MT?
Things like - no. of packets with errors
- total no. of packets (since ‘reset’ of stats)
- no. of CRC errors
On Windows NT, certain adaptors (Intel) make this visible if you go into ‘properties’. I’ve not seen it on cheaper adaptors or W2K.
If this is possible, or can be included, we have many customers, as well as ourselves internally, who would use this.
Many thanks
Stephen
