determine the Bandwidth in PPPOE.
hello all ;
Now I using PPPOE sysetm , and profiles used to determine the velocities (Bandwidth).
ppp ---->profiles (+) -----> Name:shereer1 ,Local address:192.168.0.1 , Remot address:pool1 ,DNS:213.221.221.211,
---->Limits—>Rate Limit: 192k/1M
But there is a problem :frowning: I 'm not find a solution.
The ping very high, and surf the Internet is slow.
How can I Make that the server is working perfectly and good quality ???
I hope to give a different method for determining the Bandwidth of a better profile !!
What speed is the internet link you’re connecting up to the PPPoE server at the moment?
If you surf directly via the Mikrotik without using PPPoE authentication do you get similar speeds?
Try http://www.speedtest.net to check your up and down speed normally, then again on PPPoE.
