Determine wireless mini-PCI model from within RouterOS
Is there a way to determine which model mini-PCI wireless card I have installed on a RB411 routerboard without physically looking at the card?
On the “General” tab of the wlan1 interface screen it says: “Wireless (Atheros AR5413)” (which I’m guessing refers to the chipset?) and the MAC address starts with 00:0C:42:2B:xx:xx (if that is of any help).
Many thanks!
You can use this http://anonsvn.wireshark.org/wireshark/trunk/manuf to determine the brand of the miniPCI card..
it’s a Mikrotik card, most likely R52. It might be R5H or R52H, but you can check it from the default card power in the wireless section.
I also think it’s an R52, just wanted to be sure.
The “Current Tx Power” tab lists 18dBm at a rate of 6Mbps (“Tx Power Mode” on the “Tx Power” tab is left at “default”) - is this what you were referring to?
