Does work RouterOS with this device: CPU Intel Core 2Quad Q6600 2.4Gh(1066MHz,8MB,S775)tray.?
Please, anybody answer
You’re asking if ROS is compatible with that CPU? Of course it is.
Your worry would be the compatibility between the IDE controller and the rest of the motherboard.
Try posting what you’re using as far as a motherboard and ask if there is anyone with experience with it.
But I read that Mikrotik RouterOS isn’t support multiprocessor PC ? (
ROS v3 does support multi-core, multi-cpu systems.
2.9 don’t do muli-cpu/core, however, it should still run on platforms like that.
I want to Install MikrotikOS 2.9.27 on my PC, but he doesn’t found my HDD (.
I have SATA RAID(mirror) HDD, but MOS doesn’t work (
Can I run MOS on VMware under Fedora8 OS, does MOS work correctly?
And how Can I buy MOS v3 from Republic of Moldova?
You can buy MT right on their site…
As far as installing, I think you need v3 to run SATA drives, all depends on the chipset
As far as VMWare, I have tested using Microsoft Virutal PC and Virtual server. Not VMWARE.
Works for VMWare Workstation Ace Edition 6.0.2 build-59824 without a doubt =)
