josu
1
I buy a Mikrotik Cloud Switch Series (CRS109-8G-1S-2HnD), I just upgrade the firmware and now it doesn’t boot.
I connect with serial and I get this:
RouterBOOT booter 3.19
CRS109-8G-1S-2HnD
Authorization: failure
How could I rescue the device?
I will appreciate your help.
Best regards.
Have you tried netinstalling it? Upgrade it again, and make sure to upgrade firmware.
josu
3
Thanks for the reply.
Where could I found the firmware?
I never upgrade fron network, need I configure a TFTP server?
Thanks for your great help.
Firmware is already contained in ROS.
System > Routerboard check there, click on upgrade, reboot.
josu
6
Thanks pukkita,
The problem is that I can’t access to the web interface, I only have serial access to the device.
Kind regards.
