I don’t have another install to check this on, but I just ran into a strange issue with Dude.
If I open a Mikrotik Device from the device tree (properly configured with both RouterOS password and SNMP), go to the RouterOS tab, and then go to either the ARP or Neighbor tabs, the IP is shown with a reversed dotted quad order. That makes right-click → add device pretty pointless in that tab. I should note that the ARP table via SNMP is correct however.
This is Dude 3.4 running on an RB600A, with the client being Dude 3.4 on Windows Vista Business. The MT devices I’ve looked at within Dude are v3.22, v3.19, and v3.28 - all show the reversed IP address.
Can anyone else confirm this? Is there a setting to change this? Specific to Dude PPC?
Brad
