Amongst my many RBs I also have an old one, an RB750GL.
Was sitting on the shelf for many years as some old backup, but hasn’t seen much usage. Not I’ve put it to use in my home network.
Today I cleaned the dust off of it and decided to upgrade to ROS v7. I noticed a much higher RAM usage (well, not unexpected).
Knowing that with ROS v7 one can’t install individual packages I was reading about device-mode. Great: I went ahead and tried to change to “home” to turn off most unneeded features, to see if I get some more RAM out of it.
Turns out, on this device at least, “it won’t bugde”.
I try to to this:
[admin@MikroTik] > system/device-mode/update hotspot=no socks=no l2tp=no ipsec=no
email=no pptp=no proxy=no romon=no smb=no zerotier=no
update: please activate by turning power off or pressing reset or mode button
in 4m52s
-- [Q quit|D dump|C-z pause]
Or this (it doesn’t matter what I try):
[admin@MikroTik] > system/device-mode/update mode=home sniffer=yes
in 4m54s
This device has a reset button. When I press it, nothing happens.
Tried to power it off, but after reboot it stays in the same mode as before. No change.
ROS v7.11.2, routerboard firmware upgraded as well to same version. RB750GL.
Seems like I can’t switch device-mode. I haven’t tried on any of my other routers, but, it looks like a software issue.
Edit:
Device is clean, this is all the config I have, nothing more:
[admin@MikroTik] > export compact
# 2023-10-02 01:17:44 by RouterOS 7.11.2
# software id = CS63-1W5B
# model = RB750GL
# serial number = 2C5E02AFB6D8
add name=bridgeLAN
add bridge=bridgeLAN interface=all
/ip dhcp-client
add interface=bridgeLAN
/system clock
set time-zone-name=Europe/Zagreb
/system note
set show-at-login=no
/system ntp client
set enabled=yes
