Well if they are ubiquiti Access points, they typically accept the trusted vlan as untagged and the other data vlans are tagged. Will assume this is the case. Typically a bad security idea to consider servers in any management interface ( I meant where admin may likely want to access config from )
Be advised all smart devices ( switches and APs ) that can read vlan tags should get their IP address from the Management or trusted vlan, in this case vlan15 private.
The switch is setup incorrectly in regards to /interface bridge ports, as its is contradictory to state aka, OP is confused, admit only vlan tags (which indicates a trunk port ) but then apply a PVID as well, (which indicates an access port).
Now with ubiquiti devices expecting both an untagged and tagged vlans, would be considered a hybrid port and in this case frame types is the default (ALL) and a pvid is included.
Decide on what IP addresses you want to give to smart devices, in this case the MT switch, create the static lease in the router for mac address and assigned IP. Then simply make the address on the switch and get rid of ip dhcp client.
To configure switch or any MT device from a safe location, unaffected by vlan or bridge screw ups which do happen. Configure on offbridge port. In the case below once done, simply plug laptop into ether5 change ipv4 settings to 192.168.77.2 and with username and password should be in.
SWITCH
add admin-mac=04:F4:1C:47:77:F4 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes frame-types=admit-only-vlan-tagged
set [ find default-name=ether5 ] name=OffBridge5
/interface vlan
add interface=bridge name=PrivateVLAN vlan-id=15
/port
set 0 name=serial0
add bridge=bridge comment="Router trunk port" frame-types=admit-only-vlan-tagged \
interface=ether1
add bridge=bridge comment="Garden AP - Hybrid Port" frame-types=admit-all \
interface=ether2 pvid=15
add bridge=bridge comment="S. Fabian - Access Port" frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=15
add bridge=bridge comment=PV-Anlage frame-types=\
admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
add name=MGMT
add interface=privateVLAN list=MGTM
add interface=OffBridge5 list=MGMT
set discover-interface-list=MGMT
add address=192.168.44.xx interface=PrivateVLAN network=192.168.44.0 \
{ set a static lease on the router that matches for mac and IP }
add address=192.168.77.1/30 interface=OffBridge5 network=192.168.77.0
/interface bridge vlan
add bridge=bridge comment=ServerPorts tagged=ether1,ether2 untagged=ether4 \
vlan-ids=10
add bridge=bridge comment=PrivatePorts tagged=ether1 untagged=ether2,ether3 \
vlan-ids=15
add bridge=bridge comment=GuestPorts tagged=ether1,ether2 vlan-ids=20
set server=192.168.44.1
dst-address=0.0.0/0 gateway=192.168.44.1
/ip hotspot profile
/system clock
set time-zone-name=Europe/Vienna
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=MGMT
Now if in your case the AP, the ubiquiti is not setup bass ackwards and is like normal smart devices ( all vlans come in tagged aka a trunk port the following would have to be amended for ether2 stuff.
interface=ether1
add bridge=bridge comment="Garden AP -Trunk port" interface=ether2
vlan-ids=10
add bridge=bridge comment=PrivatePorts tagged=ether1,ether2 untagged=ether3 \
vlan-ids=15
