Hi Mikrotik forum members,
I’m a new Mikrotik user, having fun setting up my first devices. I’ve managed to take a few hurdles, finding answers in various forum posts here. However, I’m as yet unable to tackle my current problem. Any pointing in the right direction is much appreciated.
The issue:
Connecting my laptop to the switch does not give it an IP. Connecting to the router gives it an IP in the configured dhcp range.
My setup:
Router: CCR2004-16G-2S+, running RouterOS 7.5
Switch: CRS112–8P-4S, running RouterOS 6.49.6
Connected using XS+DA0001
Extra info:
I’ve configured the router using this getting started guide: https://help.mikrotik.com/docs/display/ROS/First+Time+Configuration
I’m using the default config for the switch, adjusting only some settings as needed to be connected to the router
All firewall rules in the router are currently disabled to make sure that’s not the problem
The ether2 setting in the switch was used for a direct connection with my laptop when the connection with/through the router was not yet working
The router ether2 ↔ switch ether1 connection was used until I got the DirectAttach cable working (on router sfp1 ↔ switch sfp9)
Router config export:
# oct/07/2022 18:41:03 by RouterOS 7.5
# model = CCR2004-16G-2S+
add name=local
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no speed=1Gbps
add name=listBridge
add name=dhcp_pool1 ranges=192.168.79.100-192.168.79.254
add address-pool=dhcp_pool1 interface=local name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=local interface=ether2
add bridge=local interface=sfp-sfpplus1
add bridge=local interface=ether3
add bridge=local interface=ether4
set discover-interface-list=listBridge
add interface=local list=listBridge
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.79.1/24 interface=local network=192.168.79.0
/ip cloud
set update-time=no
/ip dhcp-client
add interface=ether1
/ip dhcp-server lease
add address=192.168.79.3 client-id=xxx mac-address=\
MAC-of-switch-ether1 server=dhcp1
add address=192.168.79.2 client-id=yyy mac-address=\
MAC-of-switch-sfp9 server=dhcp1
add address=192.168.79.0/24 dns-server=192.168.79.1 gateway=192.168.79.1
set allow-remote-requests=yes
add action=accept chain=input comment="accept established,related" \
connection-state=established,related disabled=yes
add action=drop chain=input connection-state=invalid disabled=yes log-prefix=\
FW_Invalid_Input
add action=accept chain=input comment="allow ICMP" disabled=yes in-interface=\
ether1 protocol=icmp
add action=accept chain=input comment="allow Winbox" disabled=yes \
in-interface=ether1 port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" disabled=yes in-interface=\
ether1 port=2279 protocol=tcp
add action=drop chain=input comment="block everything else" disabled=yes \
in-interface=ether1 log-prefix=FW_Rest
add action=fasttrack-connection chain=forward comment=\
"fast-track for established,related" connection-state=established,related \
disabled=yes hw-offload=yes
add action=accept chain=forward comment="accept established,related" \
add action=drop chain=forward connection-state=invalid disabled=yes \
log-prefix=FW_Invalid_Forward
"drop access to clients behind NAT from WAN" connection-nat-state=!dstnat \
connection-state=new disabled=yes in-interface=ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.79.0/24
set api-ssl address=192.168.79.0/24 disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Amsterdam
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
Switch config export:
# oct/07/2022 18:41:51 by RouterOS 6.49.6
# model = CRS112-8P-4S
add admin-mac=MAC-of-switch-ether1 auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp9 ] auto-negotiation=no
add name=WAN
add name=LAN
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf disabled=yes interface=sfp9
add bridge=bridge comment=defconf interface=sfp10
add bridge=bridge comment=defconf interface=sfp11
add bridge=bridge comment=defconf interface=sfp12
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=sfp9 list=WAN
add interface=sfp10 list=LAN
add interface=sfp11 list=LAN
add interface=sfp12 list=LAN
add address=192.168.79.2/24 comment=defconf disabled=yes interface=ether2 \
add address=192.168.79.2/24 interface=bridge network=192.168.79.0
/ip dhcp-client
add disabled=no interface=sfp9
add disabled=no interface=ether1
set allow-remote-requests=yes servers=192.168.79.1
add distance=1 gateway=192.168.79.1
/system clock
/system identity
set name=RouterOS
/system ntp client
set enabled=yes primary-ntp=162.159.200.1 server-dns-names=""
Best regards,
H. Deur
