As the subject states, I have created a new tool (Dude Version 3.4) that is attempting to call the [Device.Password] variable. However, it does not appear to be passing the password data from the device’s properties.
The tool’s command is basically as follows:
firefox [DeviceType.Url]/login.cgi?CanopyUsername=[Device.UserName]&CanopyPassword=[Device.Password]&login=Login&webguisubmit=submit
This will result in the following:
_http://a.b.c.d/login.cgi?CanopyUsername=admin&CanopyPassword=&login=Login&webguisubmit=submit_
As you can see above, no password has been passed through. I furthermore noticed that if I try to use [Device.Password] variable in the appearance of a device (a trick we used to use if we could not remember the saved password), it no longer displays correctly. That may have been removed as a security concern, but I would still expect to be able to use the variable in a custom tool.
The above command works fine when I manually type in a password, so I know its nothing related to the syntax of the command.
Anybody run into this or have any ideas?
