I am looking for Routerboard hardware with 4 SPF and several Gigabit ethernet interfaces.
CloudRouter CCR 1036 would be ok.. but it is a bit expensive in my case.
Is there any cheaper alternative?
Thank you very much!
You can find the available models here: https://mikrotik.com/products
Depending if your “device” has to be a router or switch, you can detail that to: https://mikrotik.com/products/group/ethernet-routers or https://mikrotik.com/products/group/switches
CRS112
CRS212
CRS317
That names a few but I will stress they are switches (regardless to the cloud router part of the name) and should be used as that with only extremely minimal routing if you don’t need a lot of performance. If you want a performance router then CCR is the way forwards or x86 with 4way SFP PCIe
Can’t you use a CCR1016-12S-1S+ and just use MikroTik RJ45 SFP Modules for RJ45 ?
